Rebuilding my atc90 engine. Put new valve guides in, reamed to 5.50mm and new valves are on the way. Went to check piston and cylinder and measured 52.2mm.. I saw online they were suppose to be 50mm bore. The cylinder is stamped 89cc. Maybe a aftermarket piston?
Will post photos below.![]()
