Results 1 to 10 of 10
Thread: Handlebar Suggestions?
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    Edit: Converted Pro Tapers specs for the Contour bars to inches and added it to the 10th post if anyone would like to see those in inches and not millimeters.
    I’m in the market for a set of bars for my build. It’s got a lot of different things going on but essentially the closest thing it would come to in style would be a 200x, but it’s got a 250r front end so it would need bars that fit a second gen r. The majority of riding on this bike will be trails but I wouldn’t mind throwing this thing around a track once in a blue moon. I see alotta guys are liking atv high bend but I have a 185s handlebar mocked up on it currently and I feel anything with more rise than it has would make this thing look really goofy. I’m currently looking at Pro Taper SE bars. I measured the pull back and height to be roughly 4” and 4” on the 185s bars. I can’t run them cuz the R clamp width is too wide for the stock S bars so I’ll need a set of bars regardless. Open to any suggestions on types of bends y’all like to run. Wanting a compromise between comfortable high rise/sweep and the less goofy looking Mx bends.
    Here’s the bike with the 185S bars
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    Nov 2019
    Florida
    1,048
    She has got great lines, a suspended 185s and 250r front end. Very nice choices.
    Sorry I don't have an answer other than find a 250r replacement bars.
    May I ask what the swing arm came from?
    thanks
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Quote Originally Posted by MrConcdid View Post
    thanks
    Thanks,
    Its off of an ~02' Yamaha Warrior 350 I used the linkage from the warrior as well. Shock is off a 92 yz250. Stock 185s axle assembly bolts right up to the upper bolt holes, have to drill the lower two tho.
    3. 85 200m
    Arkansas
    2,447
    I seems like any of the generic 'ATV High' bars are close to the stock bars you're using.
    Being real, the stock bars are already pretty tall and have a lot of sweep. Just about every aftermarket 7/8 bar you'll find, close to the same bend, aluminum or steel, will have a crossbar.
    The crossbar will be the perfect height for hitting your chin, if you plan on jumping that thing.
    The fat bars may be something you'd prefer on that. Good flex, but still stiff enough, and no crossbar. You'll have to keep in mind the height added by the adapters, and figure that into the total bar height.
    I have a ProTaper, Raptor bend on my YTM200. With the adapters, they're really up there. This is a hardtail though, so having a good bar height while standing was important.
    The stock bars, with the metal counterweights, are about the smoothest riding bars you can use, but they bend really easy.
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Thanks King,
    About how much height did those adapters add? That contour bar does look good.
    3. 85 200m
    devore,ca
    1,056
    Take a look at the bars that come on a YFZ 450 quad. I'm running them on my 450 trike and really like them. Nice and compact. Pro Taper.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Can anyone confirm if these fit an 83/84 250r triple clamp? There’s no specs on pro tapers website.
    http://www.protaper.com/product/105/...ndlebar-mounts
    3. 85 200m
    Arkansas
    2,447
    They should. 7/8" bar clamps are 7/8" bar clamps on most things. It's a standard shared by domestic and foreign motorcycles and ATVs.
    You already found the answer I was going to post. They raise the bars 3/4". They're also going to set the bars back a little, because the original top mounts are slanted back.
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    I've got atv mid rise bars on my R and X and I'm very happy with them, but I'm also a shorter guy. The set I just put on the X are Pro Taper and did have a cross bar but it's removable, so it's gone, lol.
    Jason
    85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
    87 ATC 200X - restored stock other than 18" rears and nerf bars
    84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
    Eton Viper 50cc - oldest daughter's current ride
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Thanks guys. I think I'm gonna run the pro taper adapters and a pro taper contour bar in ATV low bend. Also I have a hard time comparing measurements using the metric system so I converted all the Pro Taper specs to Inches for any one else trying to decide what bar they want. The specs they have on the DennisKirk site, that are in inches, are way off so don't go by what is listed on their site. These were pulled straight from Pro Taper's site and converted in Excel.
Name:	Pro Taper Contour Handlebar Specs.PNG
    3. 85 200m
