Thread: Original tires?
    Feb 2021
    CA
    7
    Original tires?
    After many years of being a garage queen I took this out to glamis just for a camp cruiser, someone came up and said that my tires are original and should get some different tires to actually ride on, these say
    ‘Pro vector’ are they original? I haven’t had the bike that long and thought original tires a ohitsu or something like that...
    Thanks in advance Click image for larger version.
    Apr 2014
    Edmond, KS
    2,591
    I'm not a tire expert, but I think that they look like original ones. If they are, I'd follow that person's advice. I'd put others on there and keep the originals in my garage out of the sunlight. People pay good (as in stupid amounts of) money for those.
    Slidell, LA
    4,738
    If that’s an 84 200x those look to be original.
    Feb 2020
    madison
    77
    they are the original tires-i know quad tires as I sold them before in the 90s
    May 2015
    San Diego, CA
    1,801
    Not only are they original they look hardly used
    May 2009
    S.E. Michigan
    1,251
    Those tires look almost new! Great tread and condition.
    I've purchased replacement Pro Vector 701's for the Honda 350x. The replacements were labeled as "P/V 701" as opposed to the original all spelled out "Pro Vector 701".
    I've not seen replacement 200X tires, but I'd assume that they did the same there. I'd agree that if those are spelled out "Pro Vector" then they are original. If you really want to know, check out the date code stamped on the tire. There are decoders for this. The rules for the date codes changed (can't remember if it was after 2000, or some other date). But the old codes can be read to see if these were made in the 80's.
    As for use and care: I say ride them if you're riding in low risk areas. Avoid pavement, avoid trails with stumps along the side, avoid fields that have been brush-hogged which leaves lots of short pointy sticks (from the sapling trees that have been chopped off).
    If you have a 2nd set of rims, look for some cheapies to mount up for bombing around in risky areas.
    Also, store the machine with no weight on tires. My reason for this is that if the tires go flat, you won't be at risk of creating lots of stress cracks from sitting all flat.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
