Results 1 to 3 of 3
Thread: 1983 ATC 185 Airbox work around help/ideas
    Mar 2021
    SoCal
    8
    Hey Fella,
    I picked up a 1983 ATC 185 as a parts bike, however it only took a little elbow grease to get it up and running. The only thing it needs now is an air filter, currently the carb is just open. I bought an UNI air filter for it, however I cannot mount it directly to the carb. I have tried search for some generic air box tube to use, however I haven't had any luck. I am sure there is some type of work around that people have used as I am sure stock air boxes are becoming harder to find.
    If you have a redneck fix post it up, pictures would help too
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    I am running a clamp on uni filter with no airbox on my 185s. Keep in mind you will have to rejet the carb if you go with anything other than the stock airbox. I had to raise the main jet from a 98 to a 108 main jet to get to 12.0:1 AFR at WOT but I’m also running a 200x dg exhaust and have a xr200 piston/camshaft.
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    Mar 2021
    SoCal
    8
    Quote Originally Posted by ZacH_GrifF View Post
    Thanks for the input, that's how I have done it in the past with an airbox isn't present. However, in this case on my 83 185 the carb is slightly angled so that I cannot clamp the filter directly to the carb. So in the meantime I am trying to find some generic airbox tube to use.
