why does sparks just disappear?
project 185s, dragged it home a few weeks ago, finally installed a cdi, hooked the hacked harness up, hooked the black wire to the coil instead of the green one. bolted on a pull start and it sparks. Seller told me he took the locator pin off the cam for another project. I installed one off a spare cam, stuck a pair of springs on the advance weights and bolted it back together and....now no spark! swapped cdi, swapped coil, coil wire, plug. I guess I did the quick and easy things.
But it never fails to amaze me, a simple job always goes south. I bought a extra pit bike harness, im thinking if the stator checks out, I'm just going to use the entire harness with switch and all. jim
81 185s
82 185s with 85 200s motor
82 185s
and a 72 ct70
