Thread: 185 decompression cable
    Nov 2015
    Davenport iowa
    1,144
    Does anyone know why the 185 on the early years didn’t have a decompression cable but on the later years they did? Was the compression not the same? We don’t work on these enough to know the difference. We have a customer trike that has the lever on the head but the wrong recoil with a fresh top end done to it and it pulls tight.
    1974 original 90 X 2
    1974 Original 70.
    Apr 2014
    Edmond, KS
    2,591
    I think that the compression ratio was the same. I'm guessing that it was switched to automatic release for ease of use. I don't use the decomp lever on my stock compression 185s.
    Arkansas
    2,447
    I prefer the manual lever instead of the recoil actuated one, for the ease of clearing a flooded engine. Just reach over, hold it up and pull the rope a few times. I put my elbow on the throttle to hold that open. I also like doing that before I start them if they've been sitting a while, to splash a little oil around before they fire.
    If the mismatched parts bothers them, see if they want to pony up what it takes for the correct recoil. Otherwise, watch them start it, to see if they could use some refinement on their technique.
    Nov 2015
    Davenport iowa
    1,144
    Yeah good thoughts. We haven’t tried starting it yet but are hoping for a 1/2 pull start if everything is set right
    1974 Original 70.
