Thread: Ran great last year, but not this one.
    Jul 2020
    Powell Wyoming, USA
    19
    Ye olde 1983 ATC 110 worked PERFECT last year. then it sat, ran great, until I started riding on it for a little bit. I lost control of the throttle, and then the engine stopped. it hasn't ran since, even got some fresh fuel. problem is, it has a cheap Chinese replacement carb, but i do have 2 originals, because, when we bought them, there were 2 and we built 1 good one, and one for parts i will probably get a carb kit for it and see how well that works. also, it has three of these tires:
    1983 Atc110
    1984 Atc200ES Big Red
    1964 CT200 Trail 90
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by 83Atc110 View Post
    Yep if you have spark then your issue is that junk carb. I would definitely pull that oem carb apart and see what type of pilot jet you have screw in or push in. The kits only come with screw in pilot jets.
    1974 original 90 X 2
    1974 Original 70.
    Jul 2020
    Powell Wyoming, USA
    19
    it runs, so it has spark, it's just that POS carb
    1983 Atc110
    1964 CT200 Trail 90
    Jul 2020
    Powell Wyoming, USA
    19
    i will also mention this: it leaks a little oil when it gets warm
    1983 Atc110
    1964 CT200 Trail 90
