Will Honda Recon rear rims work on 86 ATC250SX rear? If not will 1st gen 200x rims work? I know they wont work on 85 but 86 has smaller rear brake.
Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
rear wheel bolt pattern is 4x110. every honda uses that about. if you run a spacer you can run different rims to clear the big brake drum
