Thread: 8x6" rim vs 8x8" rim
    Nov 2015
    Davenport iowa
    1,144
    What does the 8x6 rim do to a 20-11-8 or 22-11-8 tire? I am assuming it makes it taller? I would also assume with the additional height that it won't clear a front fender.. Trying to find a 8" 3-bolt aluminum rim for a 90.
    1974 original 90 X 2
    1974 Original 70.
    6,811
    Would probably be difficult to install on the 8x6 rim but if you did , it would definitely make it a little taller .
    I would think it would still clear the front fender though .
    Those 8x6 rims were primarily used on the fronts of the Honda Odyssey .
    I’m using one on my full Suspention 185s but with a skinny tire . Works great .
    Attached Thumbnails Attached Thumbnails 52565A05-17A9-4743-B77F-2A980483C286.jpeg
    Nov 2015
    Davenport iowa
    1,144
    That's a good look Shortline, what size tire is that?
    1974 Original 70.
    6,811
    I believe it’s a 20x7x8 tire
