Thread: 77 atc90 barnfind
    Jun 2021
    Mt Pleasant , NC
    8
    77 atc90 barnfind
    I bought a 1977 atc90 on a pallet that has been in storage 25 years. It’s all there with good rear fender , decent seat foam, spark on ignition but only 60 psi compression. Mostly surface rust and dust. I pull the carb and found a barnacle mess inside. I already ordered a oem carb rebuild kit but I think a new one is probably in order. Where is the best place to buy a replacement carb. Not trying to do a show quality restoration but a good collectible rider.
    6,808
    Your best to either rebuild your factory carburetor or buy a good used rebuildable one .
    If you would like a little more power you could upgrade to a 1979-85 Atc110 carburetor .
    The aftermarket new carburetors are a last resort option in my opinion , most are junk and not jetted correctly .
    Jun 2021
    Mt Pleasant , NC
    8
    A buddy of mine , actually he sold me the atc90 , just bought an ultrasonic cleaner and he said he would try and clean it.
    MN
    3,263
    Cleaning the original is the best way to go. As for the compression, if its been sitting 25 years it could be stuck rings, put some PB blaster or whatever your preferred penetrating oil is down the cylinder and let it soak for a couple days, get it running, warning it will smoke like crazy burning that stuff out so don't panic, and after running it for a while see what the compression is then. That is if it runs, could be a sticky valve not closing all the way to, will just have to see after getting a working carb on it. But 60 psi is pretty darn low.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
