Thread: 350x valve cover?
    az
    2,013
    350x valve cover?
    will the valve cover come off a 350x in the frame? just got the decompression cam, cable and bracket and need to get it installed. thx. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    Feb 2017
    Corona CA
    858
    Yes. Tank and upper motor mounts removed of course , I think a few other minor things to get out of way but I’ve done it to get rid of an oil seep once.
    Sent from my iPhone using Tapatalk Pro
    az
    2,013
    thanks! I was told the trikes got a new top end, I didn't get any info on what piston was installed. the decompression lever and cable is wrong so not working. Even with boots on I can barely get it started with my bad knee.
    Anything I need to watch out for when installing the decompression cam in the head? jim
    81 185s
    82 185s
    and a 72 ct70
    Feb 2017
    Corona CA
    858
    Not that I can remember , I just followed the tear down manual. Mine has a 12-1 comp piston with a real aggressive cam. My decompression lever is there , hooked up , and adjusted “correctly” and doesn’t work at all. You can disconnect it makes zero difference. I think it’s because of the cam. I have to get mine to top dead center and then just stand on it (I’m 200 plus gear ) till it goes a little past then stomp it starts great. I feel your pain. Luckily my repaired knee is on the other side.
