Results 1 to 7 of 7
Thread: Recon Rancher brake Drum shoes help
    Dec 2009
    illinois
    1,765
    I've always had an issue with the 250 RECON and 350 Rancher brake Drum shoes. I've used emgo and EBC but the braking power isn't very good at all. I bought a 2007 Recon One time and it had the best brakes I've ever seen , it was like it had power brakes. I just installed a new rear brake drum and Emgo brake shoes on a 350 rancher and it sucks to barely slow it down at all. Is there a secret or certain shoes that have the best braking power???
    Tionesta, PA
    5,747
    1st thing - try OEM Honda shoes. I know they are WAY more expensive, but I bet you won't have issues. The only other issue is you drum might be out of spec. Measure the drum and check specs on it.
    6,808
    I second on the use of OEM shoes also make sure the axle bearings are still good/tight .
    Dec 2009
    illinois
    1,765
    Yup..I put OEM Honda shoes on today and it does brake better. I have a new brake drum but the brakes still stick! I have to pull back on the rear brake arm .. could it be the spring is too weak being it's so old?Screenshot_20210630-223004.jpg
    Tionesta, PA
    5,747
    If the arm is not returning, you need to "recondition" the most likely ungreased, slightly rusted surfaces. You'll need to pull everything apart to do this. The area of concentration is the hole and rod where the arm pivots. Pull everything apart - clean well with round wire brush and or emery paper. Grease liberally and reassemble. Your problem will go away. This is actually overlooked maintenance that should be done at least once every few years.
    Dec 2009
    illinois
    1,765
    Although that is a issue in some cases but in this situation it's different. I always clean and lubricate the brake arm shaft so that wasn't the problem.. I also installed factory HONDA brake shoes with a BRAND New brake drum thinking that would cure the sticky brake issue but it didn't. It sticks pretty good , never seen anything like it.. i can remove the brake Drum and the brakes do not stick at all.. the shoes are sticking to the Drum just like the old one did. The return spring on the brake arm must be too old and weak, just cannot be anything else but still those shoes should not stick to the Drum like that.
    May 2004
    Huffman, TX
    114
    You know superAtv and Highlifter makes disc brake conversion kits right? If you install them properly(with the competent master cylinders made for disc brakes) then they will work and stop you like disc brakes should...but...if you run them like most people and use with the stupid brake cable design on the rear, and the super weak drum brake master cylinder on the bars, then the stopping force ain’t all that great, but do work.
