350x kick start stuck.
I installed the correct decompression lifter, cable etc andth trike would kick fine the other night when I was done. today, I filled the stator cover hole where the chain wore a hole. I didn't push anything in it, just made a cap with jb weld.
I started messing with the trike and the kick start is locked up, won't let me kick it over. I pulled the ig and still stuck. put it in gear, rocked it back and forth while pushing down on the kick start and it freed up, kicked over fine about 10 times and got stuck again. Is there anything under the stator cover or should I just pull the head and make sure nothing got left behind? jim
81 185s
82 185s with 85 200s motor
82 185s
and a 72 ct70
