Results 1 to 3 of 3
Thread: Will 83 and up topend fit on a 82 and down yt175 tri-moto ??
    May 2003
    Shediac, New Brunswick
    1,126
    Including, cylinder, head, carb, intake etc .. the whole topend ?? also what about the piston, with the 82 rod and stuff ?? ...
    '84 Honda 200x
    slow restro
    SE Minnesota
    533
    Yt175
    As far as I know, the YT175 was only produced in 82-83. I believe that the only difference between the two is the addition of a vacuum operated fuel pump on the 83. the two should be interchangeable.
    83 YT 175
    85 ALT 125
    May 2003
    1,126
    alright thanks, the only difference that I see it the carbs the 82 is a 24mm and the 83 is a 20mm atleast thats what I think VM24 and VM20 mean. Is the mm the size of the carb going into the rubber intake? also will the vm24 slide fit into the vm20 slide hole?
    '84 Honda 200x
    slow restro
