Thread: Making a big red thumb throttle for hardtail
    Jun 2015
    stonecreek ohio usa
    654
    Hey guys, searching for some info on how to make a bigred thumb throttle work on a 185s. I got it on there but it seems the cable at the carb end could use a shorter casing on the throttle cable. Meaning that it is partially opening the throttle. Didn't know if there was another cable some of you guys to make this work. Thanks
    Nov 2019
    Florida
    1,048
    you could rig it, but I wouldn't. order the correct cable.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    6,811
    Atc 200s throttle cable should work .
    https://www.ebay.com/itm/37347287043...kAAOSwmoNfY8bf
    Jun 2015
    stonecreek ohio usa
    654
    Thanks shortline
    Tionesta, PA
    5,747
    Yup - shortline is correct - in 1985, the 200S (and all Honda ATCs I do believe) started using a much more modern throttle box. I think the 1985 ATC200S uses the same throttle box as the 200X and it is super similar to the Big Red as well.
    Jun 2015
    stonecreek ohio usa
    654
    Yup,as soon as I saw the part that shortline shared with me I saw it immediately. The throttle end of cable will screw into the thumb throttle assembly exactly like the big red and I noticed alot more cable at the carb end.!! I'm pretty happy about it. I gave 20 bucks for 2 bigred throttle assembly's off of big bird at trikefest.
