Results 1 to 8 of 8
Thread: 1986 Tecate front brake line length.
    Dec 2013
    Does anyone know the stock length for the front brake line on a 1986 tecate?
    Dec 2013
    Does anyone know another bike's brake line that fits?
    Mexico
    9,019
    Quote Originally Posted by whyat View Post
    If you can figure out your length you can contact a company like Speigler and get one made for a pretty reasonable price.
    It sucks to get old
    Buffalo, NY
    1,996
    I just came across what I believe is a tecate front brake setup and it measured 50"s. I'll try to confirm that later
    Buffalo, NY
    1,996
    Confirmed 50 or 51", depending on if you measure from the center of the banjo or the start of the actual line.
    Apr 2019
    Greece
    58
    Hello buddy, stock line length is 1300mm or 130cm BUT it's not only the length you have to figure out, it's also the difference in degrees the two ends have from each other. (the eyes that the oil bolt's go through)
    Mar 2017
    Antrim county, MI
    54
    Off road innovations has exact oem replica brake lines for the front for $125, or a pair of aftermarket front and rear for $120 a set.
    Mexico
    9,019
    Quote Originally Posted by Antreas Sp View Post
    That’s the beauty of the Speigler Brakes lines. The banjos swivel, so you just need to order the correct angle and then adjust it with the little clamps they provide.
    It sucks to get old
