Results 1 to 9 of 9
Thread: 1978 atc 90
    Sep 2021
    San Antonio tx
    4
    1978 atc 90
    Need help
    78 atc 90 has spark and new carburetor but it wont start. Check points and they seem to be in good shape what am i missing???
    6,802
    Check compression
    Sep 2021
    San Antonio tx
    4
    What should compression be?
    Check compression
    6,802
    Should be anywhere from 150-190 but as long as your 100+ it should run .
    Sep 2021
    San Antonio tx
    4
    Compression was 45lbs so definitely needs a rebuild. Who sells a top end kit
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by Alfredo3 View Post
    You can find a piston and rings on either this site or eBay. You’ll need to decide if you want to go hi Performnce with the piston or just a basic over bore. Going big ( high compression) will sip into the pocket book a bit because you will then want a performance cam, bigger carb and ported head. Decide what route you want to go and then start pricing your options
    1974 original 90 X 2
    1974 Original 70.
    Apr 2014
    Edmond, KS
    2,591
    Before you dive into the top end, check your valve clearances to make sure that the valves are closing all the way.
    Sep 2021
    San Antonio tx
    4
    6,802
    No that kit won’t work . A trx90 is a completely different motor .
