Results 1 to 7 of 7
Thread: drill it out
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    398
    drill it out
    I have an exhaust bolt that was broken off below the surface on a new project that I recently picked up. I went to drill it out and after breaking a few bits, I realized that someone else had already attempted this and broke a drill bit off in the broken bolt.
    What kind of bit do I need to try and drill this out? Any suggestions?
    Nov 2020
    Pine barrens
    30
    a carbide drill bit will drill through. it has to be solid carbide, not coated. sometimes they have straight flutes. i drill through bearing races and everything with them. works best in drill press at slow speed cause there very brittle.
    Mexico
    9,018
    Short of a drill press and proper methods, I’ve used tiny stones on a Dremel to get through the bit and make a hole for another bit or an easy-out. That said, using a machine shop to remove it is the best way by far.
    It sucks to get old
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    So the best way to do it is set it up in a Electro Arc burn-out machine if you can find someone with the right size collects and tubes. Or, with a mill you could easily drill it out using carbide bits and slow speeds and lots of oil. But all of that requires removing the head and I don't think you can get around that.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Jul 2019
    Shelton
    96
    I've drilled out many on a mill either with carbide drills or end mills to nibble away at it. If you get in a jam pm me. You're going to have to take the head off. Carbide drills in a hand drill are a bad idea they are very brittle. You need the rigidness of a milling machine.
    Jul 2019
    Shelton
    96
    Mar 2020
    Palestine, AR
    398
    Thanks to all: I have contacted the machine shop and they told me to bring it on in. I have an 83 year old neighbor who wants to try and get it first. I'll keep y'all posted. Thanks for the help. I appreciate it.
