atc 200es regulator plug wiring
I'm trying to wire up an atc 200es regulator to a 185s and need help with the plug. I know the red goes to the battery, the green goes negative of the lights or green from stator, I don't know. Then I'm left with 2 yellow wires, which goes to stator and which goes to lights.
Below is a link to the regulator
https://www.ebay.com/itm/36338228389...UaAjykEALw_wcB
I may help you if you can be more specific about what your intended use is.
You'll need a battery or capacitor when using that rectifier/regulator and to make a wire harness that goes from the stator to the rec/reg then back to the main harness.
//ArrowChat Integreation Code
