Page 16 of 29 FirstFirst ... 6 14 15 16 17 18 26 ... LastLast
Results 226 to 240 of 432
Thread: 1984 Honda 200X Rescue
  1. #226
    May 2015
    San Diego, CA
    1,798
    Quote Originally Posted by TexFest View Post
    i just remembered, that i have a whole 200x bottom end if you're looking for a case half
    Thank you.
    $25 worth of parts came in...mostly stuff I lost.
    The new sprocket seemed so much bigger I thought I got the wrong size. That could have destroyed the other side case.
    $1235 is the total so far.
  2. #227
    May 2015
    San Diego, CA
    1,798
    Motor coming along slowly. Had to wait for $10 worth of bolts. Cleaning fasteners and zinc plating stuff is time-consuming.
    Now that they have arrived, I can continue with the assembly of the top end.
    Still haven't addressed the chip but will do that later.
    Grand total so far is $1245.
  3. #228
    May 2015
    San Diego, CA
    1,798
    The chip has been repaired with JB Weld.
    This engine stand is so versatile.....easily flipped the motor over for the repair.
    I used a little releasing agent on the threads, so hopefully, it won't chip when the cover needs to be removed.
    I didn't do it all "pretty," but it got painted, and since it's on the bottom, it can't be readily seen.
    I'm satisfied and hoping it works.
  4. #229
    Apr 2014
    Edmond, KS
    2,591
    Doesn't look too bad.
  5. #230
    May 2015
    San Diego, CA
    1,798
    Picked up this headlight guard for $30 on Offerup.
    I was hoping I could clean it up and get that chrome to shine, but on further examination, there's too much rust....and the chrome is gone in places replaced by paint. Either way, no big deal as I'll just paint it black to go with everything.
    I always felt they looked naked without one.....just my opinion.
    Grand total so far....$1275. Already in the driveway of my $1500 budget.
  6. #231
    May 2015
    San Diego, CA
    1,798
    The motors all finished up.
    I had to disassemble the top end as the cam chain was binding at the bottom, but it's all timed and buttoned up tight......should be good to go.
    The stand is all apart and tucked away nicely, ready for its next project, which hopefully will be never.
  7. #232
    6,808
    Looks great
  8. #233
    Aug 2005
    CT
    208
    I appreciate your efforts keeping this project going and sharing it with us, The X looks amazing, I always look forward to updates on this one!
  9. #234
    May 2015
    San Diego, CA
    1,798
    Quote Originally Posted by floydechoes2000 View Post
    Thanks guys.
    Now that the motor is finished, I have to decide whether to just install the motor with everything as is.......or refinish everything and service items that need to be serviced. Everything in my being is yelling at me to just assemble things and be done with it.
    There are rust spots and the like, though. It would be nice to clean things and grease things up. The axle bearings spin freely with no play whatsoever. It feels as if it's been replaced at one point........so if I decide to paint the swingarm, I probably won't remove the axle. If I have to bang the crap out of it to remove the axle, I may upset the bearings......no need for that.
  10. #235
    207wheelin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2019
    Northern Maine
    150
    Some car guys I know call that "Patina" Knappy. I had some of that "Patina" on the bottom if the quarter panels of an old pickup truck one time. By holding the gas and the brake for a few minutes I applied some Goodyear undercoating to it and its been fine ever since.��
    ✌��207
  11. #236
    May 2015
    San Diego, CA
    1,798
    Quote Originally Posted by 207wheelin View Post
    [emoji111]��207
    Haha!
    Saw this Goki starter for a 200X on eBay for $2500 used.
    Are these going for that much?
    I hope the seller gets as much as he can for it.
    https://www.ebay.com/itm/26615977631...mis&media=COPY
  12. #237
    az
    2,001
    I've got the goki side cover and ring gear on my 350x. I understand the motors are 60 bucks. I'm trying to just get what I have into the 350x with all the extras for 1600 bucks. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
  13. #238
    May 2015
    San Diego, CA
    1,798
    This is the non glamorous gross parts of a build that nobody sees, but we all do.
    Against my better judgment, I decided to take things apart and get ready to paint things. I'm glad I did now.......as all the shock linkages were dry and corroded and somewhat seized. The fasteners need cleaning and degreasing and all that corrosion/rust removed. There's just a lot of gunk that's accumulated over the years that became hardened.
    For now, i'm just going to clean things and paint stuff and get ready to grease all the linkages and fittings and get this working properly.
  14. #239
    May 2015
    San Diego, CA
    1,798
    Swing arm is finally cleaned up and degunked.
    I'm going to stick to my initial plan and not remove the axle. There is no play or wobble or anything so why bother banging the heck out of it to get it out.
    So for now i'm just going to start sanding it lightly to get it ready for painting. I'm not going to take it down to bare metal because this is not one of those builds.
    But I am going to be bummed about that rusty axle...... which will stick out like a sore thumb against the new paint.
  15. #240
    Arkansas
    2,447
    I hear you on not getting carried away with it until it turns into a full blown restoration.
    What about getting the rust off the axle, painting it, then putting some red heat shrink on it? I think that'd add a bit of pizazz and hold up better than just paint. You'd want to keep some extra of that around because it'd have to be cut off to remove the axle nuts when the bearings need replaced.
