Thread: Ytm200 Chipped Timing Gear
    Jul 2020
    Montana, USA
    121
    Hi, since I have had my Ytm200, the engine has always had a tick to it. I have adjusted valves and the timing chain, but the noise hasn't gone away. The only thing I've noticed was that one of the teeth on the timing gear is chipped. Could this possibly be the source? Any help would be appreciated. Thanks.
    -Mike
    Apr 2014
    Edmond, KS
    2,591
    I suppose that it could be.
    Nov 2002
    Kirkville, NY
    3,831
    Pull the cam and check the lobs on the rocker arms. They often wear over time and have flat spots on the surface the runs on the cam causing a tick that valve adjustments won’t cure.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jul 2020
    Montana, USA
    121
    Once I have the cam pulled, how do I remove the rocker arms? Thanks.
    -Mike
    Mexico
    9,020
    Quote Originally Posted by Mike33 View Post
    -Mike
    Invest in a manual if you haven’t. The shafts come out with a slide , or the backyard equivalent of one, and then the rocker arms just fall out of the inspection covers. Mark them as I suspect they are identical and you’ll want to put them back together the same way they were.
    It sucks to get old
