Thread: 125m carb bowl drain O-ring needed
    Oct 2019
    Canada
    104
    Got a carb leaking at the bowl drain screw. Anybody know of an O-ring that will work?
    Honda only seems to sell 16010-943-305, which is a kit of the bulk of the carb's gaskets. I might order one anyway, but thought I'd check to see if there's something that may work.
    Thanks!
    TexFest's Avatar
    TexFest is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    U.S.
    339
    Jetsrus.com might have it without having to order a whole kit
    TPC 450R
    Mexico
    9,018
    You’re talking about a rubber o-ring that fits into a groove on a bowl drain plug? If so, anywhere that sells o rings, like Auto Zone, O Riley’s, etc should have them. Might need to buy a kit, but that wouldn’t cost much more than a single one shipped from Jetsrus. Ask for Metric Nitrile.
    It sucks to get old
    Oct 2019
    Canada
    104
    It's the one that seals the little drain screw on the side of the bowl, that empties through the tubing. I have an O-ring kit, but none are that small unfortunately. I'll look for a kit with mini sizes!
    Mexico
    9,018
    Quote Originally Posted by Baba Yaga View Post
    Reddish/yellow colored paper/fiber gasket/washer? If so that would probably be universal for any carb with a similar design. You could probably cut it out of gasket paper as well.
    It sucks to get old
