Results 1 to 13 of 13
Thread: goki starter install question
    az
    2,001
    say a person runs into a guy with a goki starter bolted to a spare 350x motor. What do I need to get this to work on my 350x if I buy the starter set up off this guy? battery and a starter switch and maybe a solenoid? how to charge the battery? He didn't say anything about having a harness, just that he's got a spare 350x motor in the shed with a goki installed that he has no use for. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    az
    2,001
    second question if anyone might have a idea. guy that has the starter has if bolted to a spare motor. what's a decent untested price for one of these? I'd like to pay the least as possible, seller wants the most. just trying to figure a price point. basically a motor, ring gear and side cover. no harness, or switch. jim
    81 185s
    82 185s
    and a 72 ct70
    6,783
    Make sure you check out the starter and ring gears , their know to loose teeth easily , Also the bendix on the starter .
    Their are two different flywheels , I believe in 1985 and 1985 1/2 , stators change as well .
    The charging system connects to I believe a yellow ? wire with a resistor for charging .
    I’ve done a bunch of these over the years but it’s been a while , I still have an original instruction manual that I can look up for you but posting pictures here is a challenge lately .
    As for price , who knows if it’s a working setup and getting replacement parts is near impossible .
    I wouldn’t pay more than a couple hundred bucks .
    If you do purchase it get the flywheel , stator and cover .
    az
    2,001
    thanks for the info, he's supposed to get back with me later in the week. jim
    81 185s
    82 185s
    and a 72 ct70
    Arkansas
    2,411
    http://www.3wheelerworld.com/showthr...-harnees/page2
    ps2fixer made some 350X Goki harnesses.
    There are new rings gears available for the '85 350X.
    https://www.ebay.com/itm/203419494723
    az
    2,001
    talked to the owner of the starter, the pricepoint or trade value he has is my running suspended 185s. So I'm pretty sure the cash price is going to be more than I feel it's worth to me. jim
    81 185s
    82 185s
    and a 72 ct70
    Nov 2019
    Florida
    1,047
    I would think any harness from a 200e or 200m would work fine. they would have provisions for the charging system and button for starter relay.
    I have seen a guy on FB making replacement ring gears and I think whole kits.
    Good luck Jim.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "The Money Pit"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    Arkansas
    2,411
    Quote Originally Posted by MrConcdid View Post
    Completely different setup.
    The 185/200 series (not the 200X) have a floating ground and the electric start versions use the same basic system with the charging and starting circuits added on. The 350X doesn't have a floating ground and all Goki done was add a single diode after the OE AC voltage regulator which makes it a half wave charging system. That type of charging is about as basic as possible and is not ideal for any modern electronics and isn't the best for charging a battery either, it's just simple and inexpensive.
    Floating the ground on the 350X would require removing and modifying the stator, or Goki providing one ready to go, which would have increased the cost and installation complexity of their kit. A full wave rectifier/regulator would have been required too, or it would defeat the purpose of floating the ground.
    Aug 2005
    CT
    207
    I bought a brand new Goki starter many years ago for my 350X. It was a pain to install and never worked correctly. I pulled it off and sold it a few years ago for nearly twice what I paid for it. My advice, stay away, it's far less hassle and way more reliable to just set it up correctly and learn how to kick the thing.
    devore,ca
    1,016
    I sold my Goki setup about a year ago for $1000. It sold right away. So yes they are very valuable. But this was a complete setup in darn near new condition. They work "ok" when installed properly and use the right battery. If they are not installed perfectly they will just destroy themselves. And there are 2 different ring gears, one for the 85 and one for the 86. The ring gear has to be set up right. Kind of like a rear end ring and pinion on a truck. Also you MUST have a working de-comp system on the trike. If you have the side cover and the ring gear you can piece together the rest. The starter from a snow mobile works. I just don't remember which on I used, and the charge wire (yellow wire) can be made up if its missing. It just has an inline diode to switch the power from A/C to D/C to trickle charge the battery using the lighting circuit. I sold mine because it was just to much of a pain in the butt to keep everything working perfectly. Starter shafts and the ring gear are deffinatly the weak links in the system.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    az
    2,001
    the owner sent me a pic today, its bolted to a motor I think he said it's got a 410 kit in the motor. and the harness and battery box is all there. he said he's had it on a few of his 350x trikes. I asked what he wanted for the starter and the motor it's bolted too. He's got to kick it around before coming up with a price. jim
    81 185s
    82 185s
    and a 72 ct70
    devore,ca
    1,016
    At the right price it would be worth trying to to see if it works for you. They are pretty easy to install and remove so it would be worth a try. You just need to have a side cover gasket on hand and a GOOD battery with cranking amps on the high side. I ran mine for a couple years and after the "cool factor" wore off I found it was more of a pain in the but than it was worth. You will have no problem selling it if it doesn't work out for you.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Nov 2008
    Buffalo, NY
    3
    Quote Originally Posted by BOB MARLIN View Post
    Hey Bob, I'm 170lbs soaking wet and really struggle to start the 350x after its been ridden and hot. Starts very easily cold. So, I purchased a Goki. Well, a Goki cover, new ring gear and aftermarket starter. I'm building the rest of the system with very little electrical knowledge. What type of battery do you recommend, amps and volts? I plan on buying a 400ex starter relay, inline fuse and a diode. I'll use 4 gauge wire for battery and starter cable, 14 gauge for the wiring harness. I posted a similar question on the "GOKI" Facebook page so, if you're on that site, no need to respond, same user.
    Thank you
