Results 1 to 10 of 10
Thread: 1985 big red 250es no spark
    Apr 2022
    Indiana
    7
    I have an 85 big red with no spark I have replaced the kill switch, neutral and reverse harness,and the cdi box( converted it to the 86-87 big red cdi with the pigtail) checked the stator, exciter coil, and ignition coil they all test good according to the factory manual. I even bypassed the ignition switch and kill switch. Also checked all the fuses all tested good. I'm definitely in need of some help any help would be greatly appreciated!
    6,801
    Aftermarket or OEM CDI ?
    I’ve never had any luck with those Chinese CDI boxes .
    Apr 2022
    Indiana
    7
    I bought an after market ricks hot shot cdi unit
    Feb 2016
    Stellenbosch, South Africa
    191
    I had the exact same issue, I tested everything and it checked out, I replaced my CDi with one from Mike's ATV and never had any problems since ....
    1983 Honda ATC250R
    1983 Honda ATC200E BIG RED (sold)
    1984 Honda ATC200E BIG RED
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 3
    1985 Honda ATC250ES BIG RED
    1986 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    1995 Honda Frankentrike 50cc 2-stroke
    2001 Honda TRX90
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
    Jul 2020
    Western Pennsylvania
    107
    I assume you already check the spark plug, plug wire, boot, and connection.
    3 Wheels:
    1982 Honda ATC 185s
    1983 Honda ATC 250R
    1984 Yamaha 225DX
    1985 Honda 250SX
    1986 Honda Big Red 250ES
    4 Wheels:
    1986 Suzuki LT50
    1987 Honda TRX 250 Fourtrax
    2023 Honda Foreman
    Apr 2022
    Indiana
    7
    Yes I replaced all of those even tried another good ignition coil
    Apr 2022
    Indiana
    7
    I will try a mikes cdi hopefully they have them in stock
    Feb 2016
    191
    Mike is a very nice guy, if he doesn't have stock and you email him I am sure he will make a plan for you. www.mikesatvfix.com
    1983 Honda ATC250R
    2001 Honda TRX90
    2008 Honda TRX250TM
    Apr 2022
    Indiana
    7
    I'm having trouble getting ahold of mikes atv fix. I've emailed him but no response. I also replaced the stator just to be sure. I'm lost at this point, does anyone know what else I could do or does anyone have a mikes cdi box for sale? Anyone live in Northern Indiana with a big red or sx that would be willing to let me test my cdi boxes on?
    Jan 2023
    New Zealand
    Im having the same issue no spark on my 200es, brought it not running and the wiring pretty hacked up i went through it all and deleted anything to do with the electric start so im down to the very basic’s but still have no spark im wondering
    If theres a everything seems to be connected properly except a single wire out of the bottom end above the reverse shaft?
    From what ive read theres a nutral safety switch that that might be my problem any ideas on how i can bypass it?
