Thread: ATC 350X engine swap
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    438
    I was just wondering if any of you guys have done an engine swap into a 350X frame? What fit easily and was worth doing the swap?
    I am referring to engines that already have electric start from the factory.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    2,591
    I don't think that anything is an easy, bolt-in swap. The simplest may be a 300EX swap simply because you wouldn't have to worry about the oil tank like you would with a 400EX.
    It's not very hard at all to add a 400EX engine to the 350X frame. Some guys sell the motor mounts that get it in the right place. You get electric start and reverse, but in stock form you lose power. The 350X engine puts out more than the 400EX for whatever reason, may be head design, exhaust, IDK. The 400EX setup must add 15lbs or so with the starter and battery, battery box etc, all things to consider. Aside from the 400EX, I haven't seen another motor that can be put in the 350X frame and have it hold up, of course we have seen people jam a CRF450R motor in them, or other combinations, but they are allot more work and "experimental" engines...
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    438
    Sounds like using the 400ex setup may require some frame gussets.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Williamstown PA
    5,825
    read this than proceed. I gave up but I had my reason. I have stuff left over to reproduce what I did.
    http://www.3wheelerworld.com/showthr...-300ex-in-350x
    Dec 2022
    newhampshire
    30
    dirtcrasher would you be able to direct me to who sells the motor mounts for the 350x 400ex transplant?? thank you!
    Williamstown PA
    5,825
    every 350x frame needs gussets, all break or have broken already. the frame need gussets even if you putting nothing in it. they were not strong at all.
