Results 1 to 3 of 3
Thread: 1985 Big red 250es starting problems
    Jan 2022
    Decatur IL
    Cool 1985 Big red 250es starting problems
    Hello all.
    Long story short, I dig this machine out of a yard and it had been sitting for 20 years. Replaced the Cdi with a Chinese one (about all I could find), cleaned carb, replaced fluids and we were off and running. Fast forward to now.
    I’ve replaced the clutch one way bearing, starter reduction gear, cleaned carb extensively, new battery, etc.
    So for a while it was running awesome no issues starting. It seems like after I replaced the one way clutch bearing it’s an absolute nightmare to start. And every now and then the kickstart lever will about break my ankle because it wants to stop when I’m trying to kick it
    It’s like every other 4th kick it tries to start. And sometimes I’ll get lucky and it will. Then it runs fines. And will mostly idle. Slight pop on decel.
    Also my neutral light will randomly flicker on as well when going through the gears
    I’m just about at a loss with this thing. Part of my thinking it may be some electrical issue. It’s almost like I can tell when it’s going to start. I’ll kick it and get absolutely nothing then all the sudden I kick down and it pops like it’s going to start.
    Hopefully someone can provide some insight. Thank you in advance
    Mar 2013
    Morristown, TN
    25
    I would make sure you are getting good connection on the neutral safety switch on the bottom right side of the engine.
    6,798
    Yes the neutral safety and the main fuse , which is located next to the CDI box and starter relay . Also the ignition switch on these are known to get bad connections.
