Thread: 350x rocker arms
    Dec 2002
    SW Alabama
    763
    350x rocker arms
    Does anyone know for sure if 250x rocker arms will work in a 350x?
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    May 2009
    S.E. Michigan
    1,251
    350x is a 4 valve head. Each rocker arm actuates TWO valves. The 250x (information that I can find online) is a 2 valve head. Nope, not gonna work. What information do you have that says this would work, or why do you think this was possible?
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Dec 2002
    SW Alabama
    763
    No, the 250x is a 4 valve head. The rocker arms look identical while still installed in their respective covers. I haven't pulled them out yet. Thinking the shaft size might be different or something. They have a different oe part number for some reason. The 250x exhaust rocker arm even has the boss for the decomp like the 350x even tho the 250x dosn't have a decomp.
    May 2009
    S.E. Michigan
    1,251
    Ok, I just googled the Honda 250x and TODAY it's a 2 valve head. (my reference: https://powersports.honda.com/atv/sport/trx250x) So evidently in the past it was a 4 valve head. For my info, what year 250x is it that you have?
    Sounds like it might be a match then based on your observation, especially since the tab for the decomp lever is there even though the 250x doesn't use it. Good luck with the swap!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    400
    Quote Originally Posted by wonderboy View Post
    You are referring to the TRX250X or TRX250EX which was derived from the honda Recon 250 which in no way is related to the 350X engine design. What the original poster is referencing is the TRX250X that Honda sold from 1987-1992. Very similar engine design to the ATc350X. However I can not answer the original posters question about fitment.
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Dec 2002
    SW Alabama
    763
    Sorry I didn't know that Honda had renamed the little 250ex to 250x. I have the 87-92 flavor.
    Mar 2007
    Texas
    5,045
    the 350D from a quad is the same rockers if I recall.
    ________________
    https://www.mikesatvfix.com
