Results 1 to 3 of 3
Thread: 1980 ATC110 Engine/Transmission Cases/Block Color?
    Toledo, Ohio
    103
    Does anyone know the color of the ATC110 block? What do you guys use which is closest to original? It's different than the rim color, is it not? Thanx
    Aug 2020
    florida
    63
    I restore a lot of old honda 3 wheelers and i use dupli-color engine aluminum paint for both the engine case and rims.
    Toledo, Ohio
    103
    Hey Harold. How close a match to the OE color(s) is the dupli-color engine aluminum paint? On other three wheelers I have restored, I used the gray/silver paint found at Tractor Supply. The name escapes me right now, but was not an exact match. I know OE color on the rims is NH-35M Cloud Silver Metallic. But, the engine case, at least on the one I'm working on, looks different than the rim color. Not sure if that is just from fading or not.
