Results 1 to 9 of 9
Thread: Plastic tank failure
    Dec 2002
    SW Alabama
    763
    Has anyone ever had a Clarke tank just split open just sitting on a trike? Tank was a few years old. Has been stored inside since new. Never had fuel in it. Mounted it on the 350x. New petcock. Put about 1/2 tank gas in. Sat for about a week.. Ran the bike couple times buy didn't ride it. Took tank off yesterday to use on another startup. Found it has split front to back on the right side. Has anyone ever seen this happen? Anyway to fix it other than plastic welding?
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    N/A
    5,818
    CALL them. id you didnt buy it new you SOL. Welding on again prob wont work, you can try but your gonna spend more time....time is money. Its the name of the game.
    Buffalo, NY
    1,994
    Clark has had some issues with 3 wheeler tanks. There were lots of complaints about the tecate tanks when they first came put. The 2nd gen tanks have a big imperfection on the left side, too
    My bw350 tank did that acouple years ago but it was a oem tank. You try to fix yours yet?
    Dec 2002
    SW Alabama
    763
    I haven't tried to fix mine yet. Using another one for now. I have a bil that loves to weld plastic. Probably gonna let him try.
    Jul 2020
    Western Pennsylvania
    107
    was the tank vented properly?
    3 Wheels:
    1982 Honda ATC 185s
    1983 Honda ATC 250R
    1984 Yamaha 225DX
    1985 Honda 250SX
    1986 Honda Big Red 250ES
    4 Wheels:
    1986 Suzuki LT50
    1987 Honda TRX 250 Fourtrax
    2023 Honda Foreman
    I think I’m going to try the soldering gun method. I’ve used it on a plastic tractor tank the some bung hole drilled a hole in to drain the fuel. And it has held for acouple months now Click image for larger version.
    6,808
    I see this issue all the time , Yamaha tanks are the worst , I believe the issue is caused from todays Ethanol fuels .
    I second that when they changed the diesel to low sulphur it caused all kinds of issues on older diesels and now the ethanol in the gas is screwing up all the old gas engines.
