Results 1 to 7 of 7
Thread: 350x clutches
    Sep 2015
    Central oregon
    350x clutches
    Can anyone give me some insight into why my 350x burned up two clutches in two days it's full of oil Valvoline 10/40 wet clutch there's no grooves in the basket everything looks good but dry
    The Open Road
    4,736
    Did you soak the friction plates in oil for at least couple days before you installed them? Takes a long time to get the oil to soak into the plates and they need to be completely soaked to work right
    Sent from my motorola one 5G ace using Tapatalk
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    196
    @ironchop that tip right there was worth the price of admission. I personally have not dealt with a wet clutch before and did not know this!
    devore,ca
    1,054
    Make sure your clutch cable is good and not hanging up inside the jacket not letting the cable relax. 350x clutches are almost bullet proof unless there’s a problem not allowing them to function properly.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Feb 2017
    Corona CA
    858
    Quote Originally Posted by BOB MARLIN View Post
    Motion pro makes them for the popular bikes 350x 200x 250rs etc for less than 20$. It’s an automatic when I buy a used bike. Even if yours works this makes it batter.
    J!m's Avatar
    Nov 2024
    New Haven, CT area
    196
    Where do you get those?
    I found a full EBC kit for $100 which seemed reasonable, but if I can save $80 that’ll buy a lot of fuel…
    Jul 2021
    Eastern North Carolina (ENC)
    10
    My First thought and Question would be; What brand clutches are you using?
    I found slipping issues when using Barnett friction plates in my modified '81 XR200R.
    This engine has;
    1) Powroll 6mm Stroker w/ 66mm bore = 218cc,
    2) Powroll Verified Ported/flowed head,
    3) VM28 & TM28 in '81R frame
    4) Powroll 66mm 10.5:1 forged Piston,
    5) Powroll Header
    6) w/ Supertrapp,
    7) MegaCycle Needle Bearing (NB) cam #143-00NS = Increases mid-range power & torque. Allows Smooth idle.
    With Barnetts, Clutch lever play constantly changed & never stayed consistent.
    Once slippage started, installed OEM clutches same day & no problems since.
    AMSinator
    https://www.amsoil.com/?zo=352885
