Results 1 to 12 of 12
Thread: 85 250es Redux
    Mar 2020
    Palestine, AR
    398
    85 250es Redux
    So I have been asking questions about this but I wanted to start over from the beginning, so here is the Paul Harvey.
    I wanted a plain Big Red to leave at my house (not the shop) that anyone could ride on a regular basis. So I started with this:
ID:	269820Click image for larger version.
    Decent shape for a project but had a very wonky and bent up front end.
ID:	269822Click image for larger version.
ID:	269823Click image for larger version.
ID:	269824Click image for larger version.
    So I took the front end apart and replaced the neck bearings, rebuilt the forks, replaced the headlight, battled and won the fight against the stuck axle, straightened, cleaned and painted the front rack and replaced the handle bars.
    Killed a snake in the shop
    Old tires with tubes and painted rims make a big difference
ID:	269828Click image for larger version.
    Replaced the battery box and have a super cool OG but cracked battery holder, cleaned the gas tank and started it up by crossing the solenoid
    Waiting on the main fuse to make it start like it should.
    Please let me know what I am missing or doing wrong?
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    411
    Looks great! You have alot of trikes!
    TRX450ER
    ATC250SX
    ATC350X
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Aug 2022
    Indiana
    19
    I like those tires. They look brand new. You sure they are old?
    2,447
    Quote Originally Posted by patriot1 View Post
    Not posting a picture of the barrel of elbow grease your using.
    Mar 2020
    Palestine, AR
    398
    Footy: I have a lot of projects lol
    bigtrout3: You are correct, the front tire is new. Rears were tubed and hit with a pressure washer.
    King: I wish I had more time for them. I enjoy the knowledge gained from trying to figure out the puzzle. Something that would take you 30 minutes to diagnose and fix might take me all day.
    Still waiting on the main fuse that I ordered on 9-2
    Mar 2020
    Palestine, AR
    398
    Well, I finally got the main fuse in the mail and installed...
    Key works and neutral and headlight comes on but still nothing from button??? Any thoughts?
    Installed a mudflap
    took zip ties out of the broke fender and welded it... (Stupid decision)
    Gave the old lady 3 beer and loaded the dishwasher
    We'll see what happens.
    6,801
    Try a test light to the two wires on the starter relay while pressing the starter button .
    If nothing then test the starter button with a Continuity tester .
    Mar 2020
    Palestine, AR
    398
    Ok guys: please help...
    Realize that I might have not performed these test correctly or that my equipment was faulty (test light)
    Test light to the relay points-no light
    Continuity test for the button showed nothing. It began and ended with the multi meter reading 1
    Changed the relay solenoid -nothing at the button
    Changed the button-nothing at the button
    Changed the ignition switch to a hacked hot wired one, crossed the red and black-nothing at the button.
    What am I missing?
    Aug 2022
    Indiana
    19
    I do not mean this is a condescending way: Is your kill switch in the correct position? Believe me when I say we have all been there...
    If your kill switch is in the right position, I'd start checking continuity of the wires themselves before things get to the solenoid. Depending on how the bike sat mice might have nibbled on something or some other wear might have occurred.
    Mar 2020
    Palestine, AR
    398
    Kill switch is correct.
    Starts right up when I cross the solenoid.
    I hate electronic stuff because of times like this.
    Mar 2020
    Palestine, AR
    398
    Well Well Well...
    Problem solved. The first two buttons were faulty. I put the third one on and it works great but the kill switch is stuck so I am going to clean it. up and try to route it correctly to the handlebars. The place all the wires connect under the headlight is no joke and not an easy place to work.
    Thanks for all advice.
    2,591
    Glad to see that you're still making progress.
