Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 39
Thread: Honda ATC 185s
    Sep 2022
    South TX
    71
    Honda ATC 185s
    Just picked up my new little project. I don't know much about these machines but from what I have gathered it's a 1983 Honda ATC 185s. Been sitting in my buddies shop for about 6 years. He said about a year ago was the last time that they ran it. I'm planning on removing the fuel tank to give it a good cleaning and cleaning the carb. Anything else I should do before trying to get it started besides giving it a good washing? Here are some pics of it.
    6,811
    Nice machine, congrats.
    Check the petcock strainer to make sure it’s good , if bad replace it or run an inline fuel filter .
    Check the oil level to make sure its safe to start it , after the first good heat cycle change the oil , Honda gn4 10w-40 is best in that machine .
    Also inspect the air filter.
    Sep 2022
    South TX
    71
    Thanks, should I go ahead and replace the spark plug as well? Is there a choke cable on this model? And as far as gears, is it 5 down or up?
    az
    2,022
    plug would be a good idea. petcock is probably toast, shifter is 5 down. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    Sep 2022
    South TX
    71
    Thanks, I'll just order a replacement petcock and replace it while I'm at it. I probably should just replace the air filter as well. What's the oil capacity on these machines? Is there a downloadable service manual anywhere available?
    6,811
    No choke cable , choke is located on the carburetor itself . That model fouls the plugs easily so if you plan on keeping it buy a few spares .
    Oil capacity is 1.43 quarts
    Quote Originally Posted by StinkerBean View Post
    Sep 2022
    South TX
    71
    Gotcha. So basically just have to manually use the choke lever. NGK DR8ES-l the correct spark plugs?
    6,811
    Sep 2022
    South TX
    71
    Thanks man. I'm pretty excited about this little machine.
    Sep 2022
    South TX
    71
    Will this manual be good to go by?
    https://img1.wsimg.com/blobby/go/462...jr7_216945.pdf
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    437
    I have the same machine in about the same shape. I also need to work on a few issues with it. Good luck with it and let us know how it turns out.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    Sep 2022
    South TX
    71
    Quote Originally Posted by Footy View Post
    Thanks and I sure will.
    Jul 2020
    Western Pennsylvania
    107
    Don't forget the air filter! It's probably dust. Mine was when I rescued my 185s from a barn!
    3 Wheels:
    1982 Honda ATC 185s
    1983 Honda ATC 250R
    1984 Yamaha 225DX
    1985 Honda 250SX
    1986 Honda Big Red 250ES
    4 Wheels:
    1986 Suzuki LT50
    1987 Honda TRX 250 Fourtrax
    2023 Honda Foreman
    Sep 2022
    South TX
    71
    Quote Originally Posted by psujeepguy View Post
    It's on my check list of things to do later today. Thanks.
    Feb 2008
    somerset uk
    44
    What a great little bike that will clean up nicely [emoji1305]
