Results 1 to 8 of 8
Thread: Help Zinc plating
    Dec 2009
    illinois
    1,765
    Help Zinc plating
    I'm needing a Rear axle clear Zinc plated for a 1984 200X, along with all the hardware for a restoration..I'm in Illinois, anyone that has a good turn around time in the U.S.? Anyone recently had this done?
    Williamstown PA
    5,825
    ZINC platers are all over the US. At work we use some here locally in PA. I honestly would not waste my time redoing a stock 200x axle unless is 100% perfect with splines. Most are not. Before you zinc which will just rust anyway I'd look into an 82R durablue axle. It would be a better investment of money and strength at the same time.
    Dec 2009
    illinois
    1,765
    So a 82R axle will bolt right up?
    Williamstown PA
    5,825
    yes same axle just flipped. I just put a 300ex axle in my modified swing arm since I didn't wanna spend $800
    https://durablue.com/product/durablu...ab-description
    Dec 2009
    illinois
    1,765
    I can't seem to find anyone to Zinc plated an axle for me .. I can get it powder coated, anyone done it before? Like to get it to look right though
    Williamstown PA
    5,825
    I've had axles powder coated. It lasts longer than zinc
    Buffalo, NY
    1,996
    A member here recomended Bass plating in Bloomfield, CT roe a while back. My buddy Matt has used them since and has been pretty happy with them. They do all the prep and are reasonably priced.
    Mexico
    9,018
    Quote Originally Posted by honda200x1987 View Post
    PC chips off when you drive, stones, brush, etc. Then the bare spots rust. I won’t do another one in PC.
    As was said above, they are all over the place. Google zinc plating, anodizing, commercial plating, galvanizing, chrome, etc plus the nearest major city to you and if the place you call doesn’t have a tank that fits your axle, ask them who does.
    It sucks to get old
