Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: Red Kote or Caswell Tank Liner
    Arkansas
    2,447
    Yep, it's a time eating ordeal. Got to plan a day for it just to have enough alone time with the tank.
    There's no easy way to pour out the excess because there's no smooth transitions to the outside of the tank. Other than prep, that's probably the hardest part.
    The other deal is air drying it. A very small fan aimed at the filler hole helps. Not right against it, but enough that it'll keep flushing the vapors out. That can speed up curing time quite a bit, otherwise you may still smell vapors even after a week of drying. The temp and humidity certainly change things and just have to deal with that for what it is. Southern weather makes everything more difficult.
    Sep 2022
    South TX
    71
    Humidity is pretty high here where I live so might try the fan idea. I'm in no hurry so plan on taking my time on a weekend. I'm debating if it would make things easier for draining if I was to thin the red kote a little with acetone.
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    I've used POR-15 before with poor results. Haven't tried red kote but after reading through the thread, I wouldn't touch it. I've since used caswell tank liner and have had excellent results. It's a much simpler process and the lining is thick. I sealed up a KLT110 gas tank that I had to patch both lower corners with screen door repair patches and JB steel stick. It's been holding for about 4 years with e10 gas in it all the time.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Aug 2020
    florida
    63
    I like Kreem fuel tank liner the best
    Mar 2015
    South Jersey
    I have a 1984 TRX 200 the tank was Full of pinholes. I used evaporust, and casewell just followed the instructions on both and now 6yrs later it's still hard and clear as glass and a perfect solution. I've seen old red coat that was a disaster. I can't say if the casewell will survive eternally, but so far so good!
    Sent from my Pixel 6 Pro using Tapatalk
    Jul 2020
    Western Pennsylvania
    107
    I've had success with caswell. Lined the tank on my 185s due to small pin holes in on small area on the bottom of the tank. Used just a dab of JB weld on the outside then lined the inside after vinegar soak and neutralization with baking soda dissolved in water. With any of these liners, it is very important to follow the instructions exactly as written.
    3 Wheels:
    1982 Honda ATC 185s
    1983 Honda ATC 250R
    1984 Yamaha 225DX
    1985 Honda 250SX
    1986 Honda Big Red 250ES
    4 Wheels:
    1986 Suzuki LT50
    1987 Honda TRX 250 Fourtrax
    2023 Honda Foreman
    Arkansas
    2,447
    Quote Originally Posted by psujeepguy View Post
    100%
    There are several quality products out there but that's the most important part.
    Nov 2019
    Florida
    1,054
    I have tried them all, I have had the best results with POR15, but it all comes down to prep.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    J!m's Avatar
    J!m is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2024
    New Haven, CT area
    177
    Do you mean the POR15 tank sealer or the regular paint?
    Feb 2016
    Stellenbosch, South Africa
    195
    I have always been interested in these tank liners but never ever used it. I'm just wondering from observation, how do you deal with the 2 fuel tubes coming out an ATC70 tank? Do you coat them too or what is the general rule of thumb with those?
    1983 Honda ATC250R
    1983 Honda ATC200E BIG RED (sold)
    1984 Honda ATC200E BIG RED
    1984 Honda ATC200X (sold)
    1985 Honda ATC70 x 3
    1985 Honda ATC250ES BIG RED
    1986 Honda ATC250ES BIG RED
    1988 Honda ATC250ES BIG RED
    1995 Honda Frankentrike 50cc 2-stroke
    2001 Honda TRX90
    2004 Honda TRX300EX (sold)
    2008 Honda TRX250TM
    1976 Suzuki RV90M (sold)
    1967 Vespa Primavera 125
    1958 Massey Ferguson 35
