Results 1 to 15 of 18
Thread: 250ES Rear Brake Issues: SERENITY NOW!!!!
    Aug 2022
    Indiana
    19
    I've got an '85 250ES Big Red with both rear brake cable adjustments (hand lever and foot lever) all the way in, but no brakes. The hand lever in particular has no braking power, but the foot lever has "some" braking.
    I'm not sure what's going on here other than the arm that actuates the brake shoes isn't turning enough to push the shoes out to hit the drum. The index marks on the arm and the cam are matched up and I've done what the manual says to do...
    At first I thought my cables were stretched out so I replaced them, no love.
    Then I measured my brake shoes, and while in spec per the manual, were a little worn so I replaced them, no love.
    I have to crank the adjusting wing nuts all the way down and compress the cable springs 100% to get what even feels like a little drag on the drum, but it's not enough to stop this beast when it's flying down a gravel road at warp speed.
    What am I doing wrong here? I've had the entire brake assembly off the bike a couple of times to play with it, but it's not making sense.
    Apr 2014
    Edmond, KS
    2,591
    Here's one possibility. Maybe the arm (at the drum) that actuates the rear brakes is not in the right spot on the splines. Maybe someone took it off and put it back on wrong. Try rotating that arm toward the front of the machine a little bit and see what that does.
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    Can you actuate the shoes/arm by hand and make it grab? Is the drum glazed up? Maybe hit it with a little 400-grit on the inside of the drum and see if it helps.
    The Goal... All I Need Is The Time...
    6,809
    Are you using OEM shoes ? All the cheap China shoes are crap .
    Aug 2022
    Indiana
    19
    350for350: I had considered that, but the index marks are lined up on the arm (at the drum) and the spline shaft, so I'm assuming that's ok. Even if I move the arm towards the front of the bike, I'm not doing anything to give myself more adjustment room on the threaded part of the cable? I was almost thinking that the cables I used to replace the old cables are too long.
    Dave8338: Yes, I can actuate the brakes shoes enough by hand to get it to grab, but it's more than what I can get the cable to pull forward. I have to really stomp on the foot lever to actuate the brake.
    shortline10: they are caltric, so chinese, but for immediate purposes I would think that since they have thick linings that should get me in the ballpark of setting the brakes correctly.
    Something else I've tried is using the adjusting nut up at the lever. I've tightened it all the way into the lever and all the way out, but nothing seems to change the overall crappiness of the brakes.
    az
    2,001
    ca you move the arm back a couple splines on the brake to give yourself more adjustment? jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    6,809
    The cheap China shoes are not cast correctly and will cause your issue .
    Their are other brands that work ok like EBC , Veserh , SOA . The China shoes will give you a long peddle with no stopping power .
    Aug 2022
    Indiana
    19
    Oh, Dang. I had no idea that could be an issue. The brakes I have on it are what was on it when I bought it a few years ago and rear brake slop has been a struggle since then. I guess I have never seen OEM shoes. I'll pick some up and hopefully that solves the issue. Thanks for the advice.
    I don't like taking things out of spec on these machines because I feel like Honda designed it a certain way to work and if I'm getting away from that I'm masking other problems and as we all know ThESe ArE dEaTh MaChInEs!!!!!
    patriot1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2020
    Palestine, AR
    398
    Post your progress and what you figure out. Listen to shortline, he is dead on correct 999.7 times out of 1000 and maybe even more than that.
    Good Quality shoes are a most but you are dealing with 35 year old drums too. We have had to add material to the actuator cam to make the brakes work ok. Even with ebc shoes. I’ve welded a old sawzall blade to each side of the flat and welded up the edge so it could be smoothed so the shoes would slide smooth on it to compensate for the drum wear. The only reason I used the sawzall blade is cause it was the right width and it was laying there lol. If you are going to try this just cut the pieces to fit and put them on each side between the shoes and reinstall the drum and make sure it doesn’t drag. Not all drums are worn the same and not all sawzall blades are the same thinkness.
    Aug 2022
    Indiana
    19
    Update: Honda brake pads came in and the outcome was the same as the Chinese brakes - soft lever.
    I suppose that means my drum is out of spec, following big specht's advice I added a shim to the flat of the brake cam. The brakes are working now.
    My next move it to try and find a better drum, although I know this one will likely last me several more years.
    I did that to acouple of the big reds we have and they have been fine for years
    Mar 2015
    South Jersey
    I have fixed this problem. Let me start by saying I lead a group of 5-7 guys to ride Big Reds in the WV Outlaw trails for 7yrs in a row. We live off the land camping and ride Big Reds every day across the rugged wilderness for a week each year. So this problem was more than an inconvenience for us. I thought my drums maybe were out of spec, a quick check with calipers told me that wasn't the case, tried different shoes to no avail! Cheap china, EBC, and even OEM. I even had custom cables made thinking the cables were all the wrong size (the housing does vary in length from different brands) None of this worked!!! Finally after Years of struggle out of desperation I tried something out of the box and it worked! The solution is easy! Your problem is adjustment, you've wound the spring tight under the adjustment wing. Take the wing, barrel and spring off. Cut the spring in half. Yes, lengthwise right in the middle. I bent the spring where I cut it with pliers to resemble the original end shape. Re assemble and BAM!!! Perfect brakes!! I'm so happy to get to share this information with fellow Big Red brethren that's also been struggling. We did it to all the bikes in the group and now have No problem with brakes. We did it to the front and back brakes on most. A couple bikes the front brakes were still within adjustment stock spring length. I've noticed no bad side effects from doing this at all. Get ready to stop that beast!!!
    Sent from my Pixel 6 Pro using Tapatalk
    Dave8338's Avatar
    Jan 2013
    Central MN
    378
    Quote Originally Posted by Shovelhead8069 View Post
    Makes sense to me. Once the spring is fully compressed you are out of travel with the cable. 1/2 the spring = 2X the potential adjustment. Good hack.
    Nov 2019
    Florida
    1,053
    Did you de-glaze the inner drum? many time the drum will have a glaze on it and it will need to be removed, I like a 2 inch wire wheel on a cordless drill.
    caltric pads are not great but will work and work well when adjusted. take the cable loose ate the drum, spin the wheel move the lever/arm by hand and see if the shoes contact the drum. Note how much the lever has to move. you may need to re-index the lever to the shaft (as already mentioned). now see how freely the cable move inside the cases? oil them if they need it or replace them if they are worn or chaffed.
    You will want to set up each brake (hand/foot) separately adjust the foot first then the hand, I do it this way because the foot to me is more important, that you can maintain hand contact with the bars and use the foot to stop.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
