Results 1 to 7 of 7
Thread: Wrinkling Paint
    Jul 2020
    Montana, USA
    121
    Wrinkling Paint
    I'm trying to paint a tank for my big red and after applying the first coat of red, it started to wrinkle up. I then sanded that down and repainted only to have the same result. Whats happening here? I would post a picture but it won't currently let me.
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    Did you apply a primer/sealer coat prior to spraying the top coat?
    What products are you using?
    What surface prep have you done?
    Typically, if the top coat ‘wrinkles’ it means that the primer/sealer or existing old paint you are trying to top coat is not compatible with the solvents in the new paint. The paint solvents are actually softening the lower coat much like a paint stripper does. This can be reduced by applying several ‘dry coats’ and allowing them to harden followed by a light sanding with 800-grit wet and applying a final coat or two of the paint you’re using to obtain the gloss; however, you still run the risk of having the whole mess wrinkle on you again. Lacquer based primer/sealer is typically the safest to use as it doesn’t readily react with most top coats. A urethane and many epoxies over an enamel without using a sealer coat will almost always do what you are describing. Other problems which can show up are:
    - fisheye: oily, waxy, or poor subsurface prep
    - orange peel from spraying the top coat too dry
    - checking from poor surface prep
    There are MANY more paint conditions which occur; however the majority are related to spraying metallics or tinted clear.
    I assume you are going with the non-metallic Honda Red?
    The Goal... All I Need Is The Time...
    Jul 2019
    Shelton
    96
    What brand paint are you using and what layer was underneath (primer, factory paint, or other paint?) Some instructions read something like recoat within 1 hour or wait 24 hours meaning if the paint dries more than an hour, your next coat of paint will soften the first coat and wrinkle. Prep, cleanness, and compatibility of products is everything in paint work.
    Nov 2019
    Florida
    1,048
    wrinkling paint is generally a chemical reaction to the base material.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
    May 2020
    S. Louisiana
    24
    If its a plastic tank the gas is leeching through. You won't be able to put decals on it either because of the same issue decals will start lifting and wrinkling as well
    Apr 2014
    Edmond, KS
    2,591
    I have heard of people putting a liner inside their plastic tanks and the the decals won't peel off. That's assuming that the liner was used correctly in the first place. I suppose the same would go for paint too.
    Nov 2019
    Florida
    1,048
    Personally I will follow Honda's lead on this one.
    85/86 250r tanks, the decals are on the scoops, I have Clarke tanks on both my 350x's and put my decals on the scoops
    I only wish the Clarke 200x tank allowed the factor scoops.
    I like the look of a metal tank, but I am tired of chasing rusty tanks
    MrC.
    My Addiction
    86 350x
    84 250r "lucky"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
