Thread: Pit bike motor in atc70
    Aug 2020
    Snowflake Arizona
    77
    Have seen this swap done before with electric start engines. Had a zongshen 110cc pit bike motor bolted it in the atc70 frame now I can't start it because the kicker hits the exhaust. Anybody got a remedy for this. Don't have fenders on it right now.
    Apr 2014
    Edmond, KS
    2,591
    My guess is that you'll have to modify the kicker so that it will clear.
    Aug 2020
    Snowflake Arizona
    77
    For now I think I'll make a grab bar and pop start it. Maybe I'll find a kicker that has more offset than the one I have there's a lot off cheap chinese bikes out there.
    Apr 2023
    Ohio
    3
    You can flip the kicker fwd and pull up on it to start it or buy a seat flip kit like mine
    Aug 2020
    Snowflake Arizona
    77
    I'd also need wheel spacers to use the kicker. Got the tires holding air filled the carb bowl with fuel and put it in 2nd gave it a push it fired right up. Just picked up a plastic Clarke tank but the carb doesn't have a on off valve will a atc90 carb work.
