Thread: Grinding after clutch replacement
    Aug 2022
    Texas
    23
    Replaced clutch plates on my Honda 110 and now im getting grinding, have anyone of you possibly experienced this?
    It shifts thru the gears fine, but once it's in gear there's quite the rumble and it seems to be coming from the LH side (High low sub transmission)
    I'm almost 100% I re-assembled the plates correctly, but maybe I over looked something or my sub trans happen to be crapping out? Does it both in low and high, while selecting the speed I do hear a slight grind.
    1980 Honda ATC 110
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by Tortuga View Post
    We put wrong screws in the hold down plate once and it made all kinds of noice before blowing the basket apart.
    1974 original 90 X 2
    1974 Original 70.
    Mexico
    9,016
    Can’t speak directly for your model, but I have seen on some engines where people have put the wrong screws in the wrong holes when reassembling the cover and a bolt that is too long makes contact with some thing rotating internally.
    It sucks to get old
    Aug 2022
    Texas
    23
    Ahhh I could have done this! I'll pull up the schematic and make sure the two long screws are in the right positions, thank you!
    1980 Honda ATC 110
    Aug 2022
    Texas
    23
    https://ibb.co/kMvqFmB
    This is the only schematic I could find...not very helpful LOL. Anyone know where I can find a better one?
    1980 Honda ATC 110
