Results 1 to 12 of 12
Thread: tri z crank rebuild kit where to buy??
    Ithaca, NY
    2,596
    I took my crank to a small shop. his catalogs dont list a rod kit. I told him I bet I can find a source before you can! Prove me right! I want to avoid the stealership. a manufacturer and part number would be fantastic!
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    May 2002
    610
    I took a look in my Wiseco catalog...Found nothing in the way of rods or cranks. You may be limited to genuine Yamaha.
    Sam from Florida
    1985 BIGRED $ 200X
    Rittman, Ohio
    6,276
    Ive got one with a Hot Rod, but it was in it when I got it. I dont have a PN#, and Id have to tear it down to get it!
    Mar 2003
    Kansas
    1,507
    1 38W-11631-01-94
    PISTON STD (38W-11631-00-94) 1
    2 38V-11610-00-00
    PISTON RING STD (STD) (25Y-1161 1
    38V-11610-10-00
    PISTON RING 1ST OS (1ST O/S) (2 1
    38V-11610-20-00
    PISTON RING 2ND OS (2ND O/S) (2 1
    38W-11635-01-00
    PISTON 1ST O/S .25 (38W-11635-0 1
    38W-11636-01-00
    PISTON 2ND O/S .50 (38W-11636-0 1
    3 214-11633-00-00
    PIN, PISTON 1
    4 93450-19052-00
    CIRCLIP, INNER 2
    5 93310-418E9-00
    BEARING, CYLINDRICAL 1
    6 38W-11400-00-00
    CRANKSHAFT ASSY 1
    7 38W-11412-00-00
    CRANK 1 1
    8 38W-11422-00-00
    CRANK 2 1
    9 2X4-11681-00-00
    PIN, CRANK 1 1
    10 24Y-11651-01-00
    ROD, CONNECTING 1
    11 93310-425N4-00
    12 90209-25085-00
    WASHER, (90209-25220) 2
    13 93306-20627-00
    BEARING (B6206C3) 1
    14 93103-30150-00
    OIL SEAL (38W) 1
    15 90280-03017-00
    KEY, WOODRUFF 1
    16 93306-20627-00
    BEARING (B6206C3) 1
    17 93103-40091-00
    OIL SEAL 1
    18 90201-12593-00
    WASHER, PLATE 1
    19 92901-12100-00
    WASHER, SPRING 1
    20 90170-12347-00
    NUT, HEXAGON
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I have been told a Niks aftermarket rod from an 84-86 YZ250 will work but I cannot confirm it.
    Ithaca, NY
    2,596
    chain that looks like factory stuff.........no thanks $$$$$$$
    Unless that is my only option :x
    Feb 2003
    southwestern NY
    641
    Try to go to www.TJPARTSXPRESS.com
    it says that the83-89 yz250 takes the same rod.They have rod kits from vesrah,#rd4001 $74.99,pro-x,#rd141$83.99,hotrod,#rd7302$83.99
    Theese kits come with all bearings washers and pins.
    Or send the crank to Gt Thunder and have him rebuild it for $125,that includes the new rod and labor to install it. Good luck
    Ithaca, NY
    2,596
    now thats good info, thanks!
    Mar 2003
    Kansas
    1,507
    cheap skate! come on.. buy some gold plate yami parts!
    Front royal, va
    2,186
    i had mine rebult at my dealership for $110,including parts and labor,my rod was good though,the only part i didnt need
    Nov 2002
    hinesville ga.
    200
    Quote Originally Posted by YTZ250#1
    I WILL CONFIRM THIS...I HAVE THIS ROD KIT IN MY TRI-Z...
    potsdam NY (upstate)
    1,437
    both dennis kirk and wiseco have crank rebuild kits
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
