Hi all,
I know there are a million threads about wiring/not starting issues on these big reds. However I did not come across any threads that addressed the issue that I'm having. Recently acquired 1983 big red. Starts and runs fine, however the key and the ignition does not kill the trike.
The key can be on, off, removed. Trike will still turn over and run. Figured it was a bad ignition or maybe some wires rubbed together. I replaced the ignition and no change. I completely unplugged and removed the ignition and the bike still turns over and the lights turn on as if the key was still in the bike and turned on. As if the ignition has absolutely no effect on the trike.
I have inspected all of the visible wiring and there eyes no sign of exposed/rubbing wires. Is there some component that could go bad and cause this?
I appreciate any help.
