Page 3 of 3 FirstFirst 1 2 3
Results 31 to 40 of 40
Thread: My last 200x build...Hopefully
  1. #31
    Williamstown PA
    5,825
    Finished my headlight conversion and its NOT BVC trikes headlight. I made my own & its all stainless steel. Enjoy.
    Attached Thumbnails Attached Thumbnails 200X-3.jpg   200X-2.jpg   200X-1.jpg   200X-4.jpg
  2. #32
    Las Vegas, NV.
    2,532
    It all looks very sano. Nice work!
  3. #33
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    440
    Looks great! I like the way the rear brake reservoir is mounted. I need to change the reservoir mount location on the 350X as the exhaust heat has deformed it a bit.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
  4. #34
    Williamstown PA
    5,825
    Been rebuilding motor and odds and ends. Just pick up me new 4140 swing-arm collar from HRE last night. Needed a few more motor parts. I used a Pro-x piston kit and the head gasket was less then perfect so NOS OEM one was ordered. Pulser coil was rebuild with all new OEM parts. It was not much at all. Way cheaper then buying 40 year old worn out parts off ebay for too much money. I bought a few sets of NOS stuff just because.
    All hardware is stainless now, brass washer used at the coil also. Seems 1 or two things just take for every to get here to proceed to the next step. I've built this motor basically out of a two junkers and parts puke'd in a box. The constant lets go see what what we have is a PITA.
  5. #35
    Williamstown PA
    5,825
    Done with motor, next intake and let's put it in the frame. Had another home project last 5months taking up a good bit of time. Still in no rush.
  6. #36
    Williamstown PA
    5,825
    Motors in, made aluminum motor spacers. Moving on. Rear sprocket and sprocket guard should be done this week. Installed a crank case breather filter last night. Almost done but still need to build a rear muffler to match my cobra header.
  7. #37
    Williamstown PA
    5,825
    I did more, now to buy a good chain. I use one I had laying around for test fitting.
  8. #38
    Williamstown PA
    5,825
    fixed up the worn out kicker to not be worn out.
  9. #39
    Williamstown PA
    5,825
    Chains on, everything adjusted and tight. Cleaning up carb now. Sat 10 years with ethanol fuel in it...glass black nastiness inside...soaking in B12 right now.
  10. #40
    Arkansas
    2,447
    Y'all doing these top notch 200X builds put a lot of the overpriced 200Xs to shame that aren't nearly the same condition.
    With yours being upgraded and modernized, it's got more value than a stocker to some people. It's crazy how that works sometimes, for vintage vehicles. It would seem they hold more value by being stock, especially original, but that's not always the case with tasteful modification.
