Thread: 83 200x kick start return spring
    Dec 2022
    NJ
    15
    Hi Guys,
    I'm looking to purchase a 200x. One of the local offerings is an 83. Seller states the kick starter works but you need to bring it back up with your foot.
    I've never worked on one of these before so just wondering how much is involved in replacing this?
    And is it still available or will I need to get one secondhand?
    Thanks.
    6,803
    Only available used , part is discontinued .
    It’s a major operation , center cases have to be split to replace that spring .
    Dec 2022
    NJ
    15
    Thanks for the quick reply. Is it just time consuming or would I need special tools? Gasket set?
    6,803
    Time consuming and a couple special tools .
    Flywheel puller and a clutch spanner socket .
    Dec 2022
    NJ
    15
    Gotcha...thanks again.
    I have an 83 200X kickstart gear repair set, pinion, ratchet and updated spring for sale.
    They are a bit buried ATM as I built an addition on my shop.
