Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: 86-87 200X FRONT wheel issue / question
    Williamstown PA
    5,825
    OK i will check them tonight.
    So what numbers are 87 200x and 85 350x?
    Feb 2013
    Ontario
    812
    What I found while I was doing my searching the 86/87 200x front hubs are the same for both years.
    The 85 350x has a slight grey black colour and has those small nipple tabs on the end of the hub. Opposite to each other. Same as the 85 250r hub. 250r is gold in colour.
    I also see a lot of 350x hubs mistaken. Behind the stud if you have a nut it’s a first gen 200x hub
    Williamstown PA
    5,825
    I know 9000% I filed the nipples off the 350x hub and they are all now gloss black powder coated. I only used the 350x hub since I knew it was same Bolt Circle for the rim I had. OK that's nailed down.
    I'm gonna put the 85 hub in the lathe and take of 3mm to center the rim. The others I'll just sell it looks like. I wanted to smaller bolt pattern so I could buy a new 11x6 wheel.
    Tonight I'll look at the casting numbers and off to eBay they go to new home fully rebuilt. I'm not building more.
    Aug 2016
    East of Worcester ma
    1,373
    Just to confuse the difference even more The 86-87 200x hub "collar" between the bearings is a different length than 250r/350x as well.......This nos 86-87 200x front axle collar is 6-1/8" long. No idea on the other 250r/350x bikes length though but do know there not the same.
    good luck.
    shep
    Williamstown PA
    5,825
    Shep,
    Already knew that. I just made a new one out of stainless last week for the 86-87 200x. It matches 83-85 200x collar too. Correct dimension is 155.50mm (6.120in)
    I didn't feel like using fuzzy old crusty metal that will rust more.
    Williamstown PA
    5,825
    Shep,
    Already knew that. I just made a new one out of stainless last week for the 86-87 200x. It matches 83-85 collar too. Correct dimension is 155.50mm (6.120in)
    I confirmed my axle spacer I bought from ATC-ATD on facebook match OEM 83-85 200x collars also. So that's cool.
    Honda made this way harder then it needed to be. Now due to every guy parting stuff out they don't have a clue to what they are really selling.
    Least the guy I bought it all off was correct in saying he had a 350x front rim and hub.
    I will win the offset front wheel game.
    Aug 2016
    1,373
    Gotcha, now get that bike done will ya. can't wait to see the finished project.
    shep
    Williamstown PA
    5,825
    I'm in the middle of redoing a customers warrior 350 and redoing my shop and being a dad...I work 10 hours a day and try to get 1 thing done a day. No rush but jeez the stuff I noticed not I cant unnoticed it.
    Williamstown PA
    5,825
    So both of my hubs have #1 cast in them. Ones same width as my 85 200x front hub, the other is crazy shorter....maybe the other is 250r?
    Let's try something else.
    Width overall of 83-85 200x hub 7.75"
    Width overall of 86-87 200x hub 7.75"
    Width overall of 350x hub?
    Width overall of 250r hub?
    My mistory hub width overall is 7.50"
    Williamstown PA
    5,825
    Got all the 83-85 stuff put on and mic'd. I need to lathe the hub .093" to center up the wheel. They are all off 3/16" inch....letting my pride get in the way. The spacers and spot on and so it the caliper mount. Never noticed this stuff and have been doing this nearly 2 decades. Already removed the studs. Hopefully in a week it can go off to power coater.
