Results 1 to 7 of 7
Thread: 1986 Honda 250sx cam chain timing/tensioning question
    Feb 2023
    Deansboro
    11
    Hey guys, I'm new here and I have a question for you. I put a new head on my 1986 Honda 250sx and timed the cam chain according to the manual. With the T lined up with it's mark and the two notches lined up for the cam sprocket and all that good stuff per the service manual. When I put my chain tensioner back in next it moved my cam sprocket timing marks off just a bit. Looks like maybe a tooth worth off but the manual doesn't mention that happening. I put the valve cover back on and adjusted the valves and I can feel it suck on the intake stroke when I turn it with a ratchet. My question is the timing marks. Is that normal for them to be off after the tensioner is installed or did I do something wrong. I went by the manual but just want to be sure. Thanks for any help
    6,811
    Your timing chain is probably worn out / stretched . Also always time the cam with a little pressure on the guide , can use your finger threw the tensioner hole . This will insure the timing is correct with tension .
    Feb 2023
    Deansboro
    11
    I bought the machine disassembled so before I get too far into putting it back together I should probably revisit the timing.
    Jul 2019
    Shelton
    96
    The tensioner only takes slack out on one side, so as the chain stretches the cam timing moves. If you are unsure consider backing it up 1 tooth to see what it looks like to convince yourself where you had it was right. A stretched chain won't line up perfect, but make sure to push on the guide to take slack out like was said above.
    Feb 2023
    Deansboro
    11
    Ok so I'm assuming that the manual is written as if I wasn't using a worn/stretched chain and the issue I have wouldn't be an issue if I was using a new chain. So when I timed it without tension on the chain, when I installed the tensioner next with my worn/stretched chain I essentially put it a bit out of time? That actually makes sense because it never crossed my mind that my chain would be worn/stretched. Am I understanding you guys correctly?
    6,811
    Not that the manual if off , even if the chain was new you have to put a little pressure on the guide to insure the slack is out to set the timing correctly , having a stretched chain just makes it a little harder to get lined up exactly , which it might not .
    Quote Originally Posted by Heavymand View Post
    Feb 2023
    Deansboro
    11
    Oh... OK I'm pickin up what you're puttin down. Any way I look at it I need to re-time it with a little tension on the chain to get it as close as possible.
