Results 1 to 2 of 2
Thread: 82’ Honda ATC 200 timing plug?
    Feb 2023
    Lac Ste Anne, Alberta
    16
    I stripped the timing plug on my 82’ atc 200. Ended up having to drill and use an extractor to get it out.
    So I need a replacement, don’t want to spend the $100 to get a new one, ($35Cdn for the plug and $35Cdn for shipping, $70 CDN =. $100 USD)
    I think this plug is used on a lot of Hondas so I am wondering if there is a cheaper replacement, I’ve seen cnc’d aluminum plugs for Crf250’s that look correct for $12 on Amazon. I did check my spares from my ct90’s and xl125’s etc but not a single plug to be found.
    Anyone know of a cheap replacement?
    Llöyd
    Apr 2014
    Edmond, KS
    2,591
    I know that you can use the plugs from a newer quad in place of the originals. I believe that ones for a 400EX will work. This also does away with the flat groove in the plugs since they use a hex key.
