Results 1 to 3 of 3
Thread: '83-85 Starter Gear... impossible!
    Apr 2023
    New Hampshire, USA
    18
    The starter gear has a broken tooth. Old, very clapped '84 200x I am going to restore but cannot find this gear anywhere. Anybody ever run a gear with a missing tooth? I'll do that as a last resort.
    This is the gear that goes onto the clutch side of the main shaft. It is #16 on the partzilla parts fiche.
    I can't find this for the 200x anywhere. Are there any other machines that used this same gear, maybe?
    Sent from my SM-S908U using Tapatalk
    6,818
    1983 is a different tooth count but 1984 and 85 are compatible , in 1985 the gears were made a little thicker but fit just the same , I guess Honda realized their was an issue . Also a few years of the xr200 were also compatible , 1990-2002 I believe .
    Here is a set , little pricey but an upgrade if yours is an 84 model .
    https://www.ebay.com/itm/20431707674...Bk9SR_SWmr34YQ
    Apr 2023
    New Hampshire, USA
    18
    [QUOTE=shortline10;1532126]1983 is a different tooth count but 1984 and 85 are compatible , in 1985 the gears were made a little thicker but fit just the same , I guess Honda realized their was an issue . Also a few years of the xr200 were also compatible , 1990-2002 I believe .
    Awesome! Thanks for the info. And the link.
