Can anyone measure their inside frame spacing at the swing arm mounts. My frame is cracked on the left side and needs repair, just want to make sure it hasn't bent or moved as well. Mine measured 13 3/4"
Also what side is you pivot bolt with the lock nut? Mine was on the left side but the manual says it's supposed to be on the right side
