Results 1 to 7 of 7
Thread: Slight play in rear wheel hubs 200x
    Dec 2022
    NJ
    15
    Hi guys,
    I have a set of trx 250 rear wheel hubs from an old project and wanted to put them on my 85 200x, to go a little wider.
    They have a tiny amount of play when I rotate them. Checked them on the axle they came off and they have play on there also. When I torque the nut on the 200x the play goes away.
    My original hubs are tight on the axle.
    Will this amount of play ruin my axle? Cause I don't want that or is this normal when using a different models hubs?
    Sent from my Pixel 5a using Tapatalk
    Jan 2014
    Prescott az
    713
    Quote Originally Posted by PineBarrens View Post
    Hi guys,
    I have that issue with my tri z. The axle splines are wore out I swapped hubs and it still did it. I put silicone on the splines and it keeps them tight for a while. It’s just a band aid until I get an axle your splines are probably worn out too.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    Dec 2022
    NJ
    15
    Quote Originally Posted by 6spdls1z28 View Post
    The 200x axle and hubs are tight with no play.
    ScreaminRed's Avatar
    ScreaminRed is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2013
    NC USA
    391
    Then your issue is probably on the wheel side, not axle. The 250 rims are the problam.
    Sent from my SM-N960U1 using Tapatalk
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    '11 Electra glide Ultra Classic
    My feedback thread: http://www.3wheelerworld.com/showthr...or-ScreaminRed
    May 2013
    NC USA
    391
    Problem....lol
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    Manheim, PA
    5,816
    THEY old, put new ones on, 400ex is a good upgrade. They do not last forever, Splines get looser on the hubs before the axle. No axle replacements but 82 atc250r
    Dec 2022
    NJ
    15
    Thanks. Yeah I ordered a new set of 400ex etc hubs not long after I posted this, as spending the $60 odd dollars was worth the piece of mind.
