Thread: 200es Pull Start Only.
    Sep 2007
    Canada
    26
    Hi guys,
    All of a sudden my bike electric start will not work. I can pull start it just fine. I tested the starter it works just fine. The battery is fully charged. When I attempt to electric start I hear a click near the battery box. My green light is on the steering column. If I put the bike in reverse the red light comes on as well. With the green light on it would indicate to me that the neutral switch is working. Any info would be great appreciated. Thanks in advance
    6,811
    Sounds like your starter solenoid is bad .
    Sep 2007
    Canada
    26
    Thanks for the response, I have one ordered. If I add power to my starter directly it will start the bike. So I am pretty certain you are correct. By doing this I by pass the solenoid which IMO does isolate the solenoid/relay as the problem.
    Sep 2007
    Canada
    26
    Installed a new solenoid and it fired right up.....Thanks again for your response
