Thread: 86' 350x smoking
    Nov 2023
    Memphis, TN
    5
    86' 350x smoking
    I have a 1986 Honda 350x, that I could use some help with finding out why its smoking so bad. I am not really familiar with these machines, it was given to me from a friend that owned it and recently passed away. I have a short video to show you the smoking. Any help would be appreciated.
    https://vimeo.com/887768647?share=copy
    Williamstown PA
    5,825
    Quote Originally Posted by Apeterson26 View Post
    It's nearly 40 years old and needs a rebuild, while in there freshening up valve seats and seals and everything else wrong. Say good bottom end is tired by now too since no one has the nuts to split a case. $1500 rebuild. Do it yourself and enjoy another 40 years.
    May 2015
    San Diego, CA
    1,800
    That looks to me like something is burning near the rear master cylinder/brake line/exhaust/etc.
    I would first remove that exhaust wrap and get a good look in that area and see what's actually burning/smoking/melting.
    The motor sounds like it's running fine.... just look in that area and see what's happening.
    Good luck
    Jan 2018
    California
    111
    Does it smoke out the end of the muffler if you blip the throttle or only on the side?
    Nov 2019
    Florida
    1,048
    based solely on your video, it seems to be running ruff, I bet you have oil/unburned fuel in your exhaust and as the exhaust heats up its burning it off and causing smoke
    Option 2 is you are leaking something onto the exhaust, I have a plastic tank dripping fuel in that same spot and it smokes. the header wrap hold liquids and as they get hot they burn off, you need to fix this asap especially if its fuel.
    MrC.
    mrc_builds on YouTube Channel
    My Addiction
    85 350x "The Nice One"
    86 350x
    85 350x "Yard Sale" Flat Tracker
    84 250r "lucky"
    85 250sx "Enterprise"
    85 350x "Code Red"
    86 250r "Unicorn"
    86 trx250r
    88 Lt250r Suzuki
    83 Z50r
    85 ATC 70
    88 KD80x
    85 CR250r
    84 KXT250r Tecate
